- Real Gasket Push Rod Tube Installation
- Frank Hamelly
15 May 2025 13:01 #1
by Frank Hamelly
Replied by Frank Hamelly on topic Real Gasket Push Rod Tube Installation
Finally done with the real gasket pushrod tube install. So far, total success. Previous owner had a catch can at the end of the Air Wolfe air oil separator hose under the cowling. That did nothing but coat tue whole engine and inside of the cowling with a vapor mist. I installed a proper outlet tube just ahead of the exhaust pipe outside the cowling. With a clean underbelly, we will see if that keeps the engine cleaner. Mike.
- Frank Hamelly
28 Apr 2025 09:37 #2
by Frank Hamelly
I guess I should have said I have an 0-200 on mine. Not sure if it makes a difference.
27 Apr 2025 21:42 - 27 Apr 2025 21:44 #3
Replied by Brooks McNew on topic Real Gasket Push Rod Tube Installation
I didn't even need to drop the exhaust to do the job. There's no interference with the exhaust flanges though, because I had the exhaust ofg and on since then to paint it.
I was more worried about the cylinder baffle "strips" that are woven between the cylinder and the pushrod tubes, but they were no problem either. Well, no more annoying than they were with the old tubes anyway!
Last edit: 27 Apr 2025 21:44 by Brooks McNew.
- Frank Hamelly
27 Apr 2025 20:18 #4
by Frank Hamelly
Did you have any clearance issues getting the exhaust flanges up past the new pushrod tubes? I am. Also found a a crack in one pipe where it goes into number 2 cylinder exhaust flange that I hope to get repaired tomorrow. Mike
17 Apr 2025 21:41 #5
I just got done installing these on one cylinder.
Honestly, pulling the nose bowl was the most time consuming part of the job. I only have three engine hours since the installation but so far no leaking at all.
Per the STC, you want to order a tube of Permatex "Ultra Copper" orange RTV (specifically), and a tube of Dow DC-4 or some similar assembly lube.
The spring compressor is definitely just a Briggs & Stratton part! I ended up buying it from Spruce because I didn't know better at the time.
- Frank Hamelly
17 Apr 2025 14:33 #6
by Frank Hamelly
I modified a GM door hinge spring compressor I had from years ago. Works great!
