Gascolator
  • Keith Whitcomb
10 Jan 2025 19:06 #7 by Keith Whitcomb
Replied by Keith Whitcomb on topic topic change from Gascolator to spark plugs
“ Surely there is a plug that can be cross-referenced to it or a reasonable USA alternative to the overpriced Champion M41E.”
And has VALID STC or is an approved plug per the Continental type certificate data sheet!
You and your Canadian owner maintenance is going to get someone here into deep doo doo with our FAA.
I can point you to plug adapters that will enable the use of cheap automobile spark plugs. No STC, and NOT authorized.
What you can do with your Ercoupe would get ours grounded by the FAA.
  • Bruce Bennett
09 Jan 2025 19:20 #8 by Bruce Bennett
Replied by Bruce Bennett on topic topic change from Gascolator to spark plugs
A Canadian Maintenance disclaimer is a good idea.
As to spark plugs. The Ercoupe originally had short plugs and
no eyebrows. My 415C has no eyebrows and I wish to keep it that way.
Don't know what plugs were original to the 75hp. Surely there is a plug
Anyone?
  • Keith Whitcomb
08 Jan 2025 18:42 #9 by Keith Whitcomb
Replied by Keith Whitcomb on topic Gascolator tractor spark plugs
I have suggested that when he posts here, he makes a disclaimer that he is operating under a Canadian owner Maintenance program, similar to experimental, and what he can do with his aircraft would not be acceptable here in the states without a STC or a 337.
08 Jan 2025 15:01 #10 by Matt Gunsch
Replied by Matt Gunsch on topic Gascolator tractor spark plugs
What he refuses to say is he is in Canada, and the Ercoupe is under owner Maintenace, almost like experimental, what he can do with his Ercoupe would get yours grounded by the FAA.
  • Keith Whitcomb
13 Dec 2024 20:56 #11 by Keith Whitcomb
Did you get an STC with those plugs, or what?
  • Robert CUTTING
13 Dec 2024 20:17 #12 by Robert CUTTING
Replied by Robert CUTTING on topic Gascolator
I think they are autolite389 will have to check next time I am out at my plane
