More information on the AD 54-26-02
29 Nov 2025 23:25 - 29 Nov 2025 23:33 #1 by Brooks McNew
Replied by Brooks McNew on topic More information on the AD 54-26-02
Yes, this is the part that the steering cables attach to, and the original ("bad" in Vernon's photos) caused a sharp bend in the cables which eventually causes fraying.
Replacing with the "good" part makes a more gentle bend in the cables that won't cause premature fraying.
Here's a listing for the new "good" part that mentions that it satisfies the AD
You can remove this part without removing the control column.. after pulling out the bolt that holds the control cables, you tap upwards on this part (the steering quadrant) working gradually around the perimeter where it's attached, and it will come off. A medium small hammer and a brass drift would be the best tools. It's only held there by friction (and age) once the bolt is out. If you want to do the whole set of bearings in the column... The whole thing will have to come out and that's entirely doable but more of an ordeal.
Last edit: 29 Nov 2025 23:33 by Brooks McNew.
  • Brandyn Byrnes
29 Nov 2025 22:25 #2 by Brandyn Byrnes
Replied by Brandyn Byrnes on topic More information on the AD 54-26-02
Thank you for the photos!
Are these what the AD is referencing when it mentions those four drawings?
29 Nov 2025 11:51 #3 by Brooks McNew
Vernon recently sent me his photos of the good/bad quadrants. Here are his photos...
27 Nov 2025 11:38 #4 by Matt Gunsch
Replied by Matt Gunsch on topic More information on the AD 54-26-02
in a back issue of coupe capers, Vern showed the difference between the old and new styles, It would have been during a national gathering, so that should narrow your search down a little
  • Brandyn Byrnes
25 Nov 2025 19:40 #5 by Brandyn Byrnes
More information on the AD 54-26-02 was created by Brandyn Byrnes
Hello everyone,
During my annual I had to inspect AD 54-26-02  by removing the control cables and inspecting them.
In the AD description it states:
"Modifications approved by the FAA which are believed to eliminate the fraying difficulties are described in the following data:
1. Drawing No. 514, change "A", Met-Co-Aire Co., Fullerton Municipal Airport, Fullerton, Calif.;
2. Drawing No. New 101, change "A," J.V. Newman, Bates Aviation Inc., Hawthorne Municipal Airport, Hawthorne, Calif.
3. Drawing No. 12, dated November 1, 1954, Ed's Airmotive, 430 Windsor Way, Renton 2, Wash.;
4. Drawing No. 415-52137, change "1," dated February 21, 1955, Vest Aircraft Parts Division, Denver, Colo."
Does anyone references to those drawings?
Thanks!
-Brandyn
Time to create page: 0.076 seconds
