Ercoupe 415-C 9CF Baggage Compartement STC and 1320lb Gross Weight STC
13 Oct 2026 22:05 #1 by Warren Hampton
337 required
26 Aug 2026 04:49 #2 by Raymond Knox
Its not “stainnless steel cowl cover”. It’s the panel over the header tank. Between the windshield and the firewall.
03 Jul 2026 14:07 - 03 Jul 2026 14:08 #3 by Larry Snyder
Converting to a D has NOTHING to do with the firewall!! It’s the skin that covers the cowl tank. It must be stainless. It also has nothing to do with the gas tank. You must:
Put a stainless steel skin over the gas tank
Make sure the orifices in the MLG are correct
Limit elevator up trsvel to 9 degrees
Have the ¾” trim tab
I believe these are required for the 1320 STC with the possible exception of the stainless steel skin.
Surely somebody must remember what to do. As far as I know an approved 337 is all it takes. Many C models were converted to D models to get that extra 140 pounds! A lot of people bought Ercoupes that were registered as 415C models and later got the FAA CD and were shocked to find the 337 that converted it to a 415D! At the time that meant a sport pilot couldn’t fly it (no longer the case).
Last edit: 03 Jul 2026 14:08 by Larry Snyder.
03 Jul 2026 13:39 #4 by David Gilson
I'm half way through the 1400 pound increase. I have the 337 approved but so far i can't figure out how to change the designation with faa. I contacted a dar that I've used previously and he said he needed to research it. If you know how that step is completed, I would live to know
11 Jun 2026 09:32 #5 by Ronald Raty
As I understand it, There is a certification requirement that the firewall not be aluminum. During certification, there were numerous modifications, one being the larger cowling that extended over the gas tank with only an aluminum sheet separating the passenger compartment from the engine. Nobody thought about how that compromised the "firewall" separation. The inclusion of the steel sheet in the STC is to correct that oversight.
11 Jun 2026 06:44 - 11 Jun 2026 06:48 #6 by B Hage
i am curious to understand how changing the stainnless steel cowl cover affect the capacity of the ercoup to carry more weight
Last edit: 11 Jun 2026 06:48 by B Hage.
