				 - Fuel indicator, floating, on 415 C...
- Ken Medlin
						27 Jul 2020 14:25				#1
		by Ken Medlin
				Replied by Ken Medlin on topic Fuel indicator, floating, on 415 C...
				replace the floats. They will start sinking at some point and need replacing.
- Ken Thompson
						11 Jul 2020 23:21				#2
		by Ken Thompson
				Replied by Ken Thompson on topic Fuel indicator, floating, on 415 C...
				You left us hanging, Steve.
- Dale Kohler
						25 May 2020 20:15				#3
		by Dale Kohler
				Replied by Dale Kohler on topic Fuel indicator, floating, on 415 C...
				Did you get your problem sorted?
- Steve McNew
						08 Apr 2020 23:41				#4
		by Steve McNew
				Replied by Steve McNew on topic Fuel indicator, floating, on 415 C...
				I got it; will call A&P in the am to confirm - The filled header was still full today; went around once and landed - measured gas in header and wing tank.  Header was down, wing not.  Went around again, a longer pattern, and header was down by a third of what it had before starting up today - wing tank not changed at all.  My conclusion is that the pump is not feeding the header.  Will run that by my A&P.  It was an interesting feeling, to have the wing tanks full, and see the bead drop out of sight when descending...
- Steve McNew
						07 Apr 2020 21:02				#5
		by Steve McNew
				Fuel indicator, floating, on 415 C... was created by Steve McNew
				Recently, the wire in the sight tube has gone to showing the tank to be partially empty - from about an inch low, to halfway down.  This usually had been corrected with the engine running a moment or two, pumping fuel into the header tank.  So - I filled the header, raising the float to its top position, but it rapidly fell to half way down.  And I am not at ease with flying, not having any sort of honest indication.  Does the cork get heavy after a few years?  It has been at least 6 years, with no problem.  Oh - also had a little fuel spraying out of the header; tightened the blades on the cap, and twisted the nut inside, to snug that on to the tube.  Have I pinched the wire somehow?  It moves easily with the cap off...   Thanks, Steve
