Jacking up the Coupe
31 Oct 2022 01:10 #1 by Ron Holmes
Replied by Ron Holmes on topic Jacking up the Coupe
I tried it yesterday, works like a champ... Thanks
31 Oct 2022 01:09 #2 by Ron Holmes
I have a rarely used anymore engine hoist... sounds pretty easy...Thanks
27 Oct 2022 17:36 #3 by Kenneth Crofut
Replied by Kenneth Crofut on topic Jacking up the Coupe
If you have a lower S/N with the welded tube main landing gear the best way in my opinion is use an portable engine hoist and strap at wing attach bolts.
  • Edward Moore
27 Oct 2022 02:32 #4 by Edward Moore
Replied by Edward Moore on topic Jacking up the Coupe
On the main landing gear at the "knee joint". stick a piece of steel rebar or a long socket wrench extension thru the "knee joint' and place suitable jack under bar and jack up Of course, chock the remaining on the ground tires to prevent movement of aircraft. FWIW
26 Oct 2022 23:31 #5 by Ron Holmes
Jacking up the Coupe was created by Ron Holmes
I know this is a simple question, but I don't know how to do it...  My annual is next week and I don't know how to jack up the airplane... Looking for help,    again...
