Questions from a newbie
23 Nov 2026 11:32 #1 by Warford Johnson
Replied by Warford Johnson on topic Questions from a newbie
Thanks vwry much, John! Now I need to find a Ercoupe knowledgeable A&P in centrall North Dakota! (I'm in southern Missouri.)
23 Nov 2026 11:25 #2 by Warford Johnson
Thanks very much! The broker tells me it has already been converted to a D model. Unfortunately the logs are not entirely complete, but there is nothing in the logs indicating the wings have been recovered since the mid-late '50s, and that recover was linen. however, the photos look like the cover is taut and the paint appears very modern and immaculate. Broker says he'll do some 'digging" about that issue. If a punch test is done and is good, I'm thinking that's proof the recover is more recent, but don't know if that would distinguish linen from Ceconite, since know nothing about punch tests. Your thoughts?
20 Nov 2026 18:14 #3 by John Jones
Replied by John Jones on topic Questions from a newbie
John-
You might want to look through this archive which has answers to your questions web.archive.org/web/20180830182409/http:...om/Ercoupe/index.htm
Many folks prefer the "rag" wings, and as Ronald said, the new fabrics have much better longevity. If you have access to a hangar I wouldn't worry about that, and you would have a useful load gain with the fabric.
John
19 Nov 2026 15:08 - 19 Nov 2026 15:11 #4 by Ronald Raty
Replied by Ronald Raty on topic Questions from a newbie
1. With a few modifications (including restricting elevator travel which restricts AOA which makes it difficult to stall), any Ercoupe can be converted to a 415D with a max load of 1400#. The mods are listed in the type certificate A718. Since the 415D is now light sport eligible, there isn't a lot of incentive to keep the lower gross weight limit.
2. Many years ago, rag wings would last about 10 years making metal wings attractive and worth the weight gain. Modern fabric systems last a lot longer.
3. Find an A&P that knows Ercoupes and particularly the AD's, many of which deal with corrosion. Corrosion is usually the deal breaker for an Ercoupe.
Last edit: 19 Nov 2026 15:11 by Ronald Raty.
19 Nov 2026 14:25 #5 by Warford Johnson
Questions from a newbie was created by Warford Johnson
Hello Folks, I'm a new member, seriously considering buying an Ercoupe. The one I'm looking at is apparently a 415 CD with fabric wings, so I need some expert advice:
1) Why does the CD have max gross of 1280, while the C is 1400? Is that due to unrestricted elevator travel somehow, or is there another reason?
2) I recall hearing many years ago that one should avoid the "rag wings" in favor of aluminum. If that's true, why?
3) What unique issues should I be especially aware of for a pre-purchase inspection on this aircraft?
Any thoughts will be greatly appreciated!
John Johnson
