- Airworthiness Directive Compliance Record Forms
- Arlan Allen
01 Nov 2020 15:08 #1
by Arlan Allen
Replied by Arlan Allen on topic Airworthiness Directive Compliance Record Forms
Ken,
I would be concerned about the competency of your IA. Part of his responsibility is to research the ADs on the airframe, engine, propeller and accessories.
I have never encountered an IA without the capability research Airworthiness Directives.
Part of your aircraft records should include and AD compliance list with compliance date/time, next due date/time.
If you have an entry in your log book stating all ADs complied with, it is not an adequate method of compliance.
Arlan
N3989H
Arlan
N3989H
- William James
30 Oct 2020 09:42 #2
by William James
Replied by William James on topic Airworthiness Directive Compliance Record Forms
have you talked to AD-Log
1-800-235-6444
1-800-235-6444
29 Oct 2020 18:20 #3
Replied by Matt Gunsch on topic Airworthiness Directive Compliance Record Forms
I wasn't going to say that, but....
29 Oct 2020 18:01 #4
Replied by Larry Snyder on topic Airworthiness Directive Compliance Record Forms
I don’t understand why you would entrust your airplane to an A&P/IA that apparently does not know how to find ADs! When I get an annual I consider a significant part of the cost to be the IA making sure the paperwork requirements are met. I would respectfully recommend finding another mechanic.
29 Oct 2020 17:12 - 29 Oct 2020 17:19 #5
Your IA can get them off the FAA website, FAA.GOV, as for the recurring, ADs, all the times are in the AD or if they reference a service bulletin for times.
Ken, I emailed you a copy of my AD Spreadsheet
Last edit: 29 Oct 2020 17:19 by Matt Gunsch.
- Ken Nicholls
29 Oct 2020 11:12 #6
by Ken Nicholls
Airworthiness Directive Compliance Record Forms was created by Ken Nicholls
Does anyone have access to a complete set of airframe and engine airworthiness directive compliance record forms? My A/I
doesn't subscribe to the service that provides them. I looked at univair and saw the a/d list and the link to the FAA website with the
description of each A/D. At the FAA website under A/D compliance I did not see what time interval the center section needs to be inspected in listed under center section inspection compliance.
They said recurring but gave no timescale just the three approved methods of inspection. Does anyone know where the timescale for this A/D is listed or can be found? If anyone has blanks for A/D compliance
and could send me a set or direct me to where I can locate some for purchase I would be great full. Thanks.
Ken Nicholls
N3324H
Ken Nicholls
N3324H
