- Prop Overhaul?
Prop Overhaul?
20 Nov 2022 17:05 #1
Replied by Larry Snyder on topic Prop Overhaul?
That AD refers only propellers returned to service by Southern California Propeller Service of Inglewood, California.
20 Nov 2022 16:31 #2
Replied by Warren Hampton on topic Prop Overhaul?
Robert, there is maybe an AD on your Prop / McCauley1B90CF or 1B90CM 2005-14-11 I have not read it yet but it is in my AD list
20 Nov 2022 00:34 - 20 Nov 2022 01:36 #3
Is it a wood Prop? Remember Wood prop was the thing in the '40s. How many hours on both Airframe and Engine? Does it have a Prop logbook? Did Bill and Ken put the 85;s prop back on when they put in the C90? Robert, I found something fromĀ 00H, the new Data plate from the CD to D that never got sent to FAA The paperwork is not here basically only thing I had to do was drill out Shock to a larger size for the1400 Lb weight limit. Email me your address. Is the prop still a Mc Cauley?
Last edit: 20 Nov 2022 01:36 by Warren Hampton.
08 Sep 2022 17:35 #4
Replied by Matt Gunsch on topic Prop Overhaul?
the prop makers say it should be done when the engine is overhauled.
- Robert Jensen
08 Sep 2022 12:02 #5
by Robert Jensen
Prop Overhaul? was created by Robert Jensen
Hi, I own an e1947 ercoupe C and it appears to have the original prop on it. Is there a tbo on the prop? How many hours and/or years?
Thank you
Thank you
