FERRY PERMIT
15 Jun 2022 20:42 #1 by Matt Gunsch
Replied by Matt Gunsch on topic FERRY PERMIT
You will require a logbook entry by a A&P stating the plane has been inspected and found safe for a ferry flight, he will also have to check the ADs to make sure that they allow the plane to be ferried, some ADs do not allow ferry flights and would have to be done before a ferry permit can be issued.
15 Jun 2022 18:19 #2 by Larry Snyder
Replied by Larry Snyder on topic FERRY PERMIT
I would think the owner of record would apply for it, since it will take the FAA ages to process the new registration. Get your permit here:
awc.faa.gov/AWCExternalApplicant/Splash/Index
  • Scott Engelhart
15 Jun 2022 17:41 #3 by Scott Engelhart
FERRY PERMIT was created by Scott Engelhart
In a case where an aircraft is being sold and a ferry permit will be needed for the plane to travel from point of purchase to it's new base, is it correct that the buyer files for the Ferry Permit?
Does the buyer need to have the plane Registered prior to applying for said permit?
I'll appreciate anyone with first hand experience.
Thanks much,
Scott
