Ercoupe O-200 STC Prop question
  • Randall Hirsch
24 Sep 2025 11:00 #7 by Randall Hirsch
Replied by Randall Hirsch on topic Ercoupe O-200 STC Prop question
Frank any field approvals in your log history for the prop? This Ercoupe had the 6950 at the time of purchase and had been through many Annual inspections without issue. This IA was the first to catch it. I suspect there are several others in the field that may have the same issue.
  • Frank Hamelly
24 Sep 2025 10:40 #8 by Frank Hamelly
Replied by Frank Hamelly on topic Ercoupe O-200 STC Prop question
Mine is a 6950 and works just fine. I bought it that way for what it is worth.
24 Sep 2025 09:20 #9 by Larry Snyder
Replied by Larry Snyder on topic Ercoupe O-200 STC Prop question
That is the best route. I’m not familiar with the TCDS for the Alon, but the Ercoupe TCDS ties very specific props to specific engines. Since no Ercoupe/Forney/Alon came from the factory with an O-200, I assume no such combination appears in the TCDS for the airplane, only in the STC. Let us know if you get the field approval - it’s always good to know which FSDOs will do that!
  • Randall Hirsch
24 Sep 2025 08:48 #10 by Randall Hirsch
Thanks for the input John and Matt! We are aware that the prop is allowed in the O-200 TCDS. My IA is working on a field approval with the feds in Nashville. Hopefully it all goes well.
23 Sep 2025 22:23 #11 by Matt Gunsch
Replied by Matt Gunsch on topic Ercoupe O-200 STC Prop question
I would have your IA read the TCDS, he will find there are minor differences, but both are on the same TCDS drs.faa.gov/browse/excelExternalWindow/1...625738D005FDC79.0001
22 Sep 2025 12:39 #12 by John Jones
Replied by John Jones on topic Ercoupe O-200 STC Prop question
I have a different prop with an O-200 on my Alon. The engine was swapped in 1994 by a 337 field approval since the STC didn't include Alons at that point in time. The prop installed was a 1A101/DCM69/50 so that's what the FAA approved for my installation. The owners soon had it re-pitched to a 69/51. I just had to replace the original prop due to corrosion in the bolt holes and my IA wanted the prop to be the same that came off so I ordered a 69/50 and had it re-pitched to 69/51. It makes the top end of static RPM and will still want to overspeed in level flight at 2500' so could probably even be 69/52. I was unable to find any new or used props on the O-200 approved list so had to wait nearly a year for McCauley to manufacture the new one.
