- Throttle and mixture cable support
12 Nov 2024 21:17 #1
Replied by Matt Gunsch on topic Throttle and mixture cable support
ADel clamps should NOT be used on engine control cables others than for support. If you are using a Adel clamp as a anchor, you are asking for trouble in the future. The only clamps to use for anchors are a metal to metal boden cable clamp such as a AN742. Adel clamps lose their clamping force when the rubber insert dries out or gets oil soaked.
- Keith Whitcomb
28 Oct 2024 15:16 #2
by Keith Whitcomb
Replied by Keith Whitcomb on topic Throttle and mixture cable support
11 Oct 2024 19:11 #3
Replied by Warren Hampton on topic Throttle and mixture cable support
Nick, what model is your Coupe? The CD started a dif configuration for the throttle. The F number would be a Forney number so it for the later Two control throttle and trim of the CD thur G models The D, I think still had the push/ pull throttle. CD started at Serial number 4501
- Away
09 Oct 2024 12:14 #4
Replied by Ronald Raty on topic Throttle and mixture cable support
My controls and wires inside the cockpit weren't that stiff, and were hanging pretty close to the control mast. I took a piece of 1/4 al tubing, flattened the ends and drilled them for #6 screws, then attached it to the bottom of the panel and to the firewall. It gives me something stiff to attach all the hanging bits and keeps them up out of the way.
09 Oct 2024 02:49 - 09 Oct 2024 02:50 #5
Replied by Brooks McNew on topic Throttle and mixture cable support
You might not need to worry about the instrument panel to firewall portion. The first few inches of the control assembly behind the panel will be completely rigid construction, and then the flexible portion is actually pretty stiff. Mine are completely self-supporting between the panel and firewall, and they're stay put so we'll that it's always tempting to attach other thing (i e. flimsy wires) to them for support.
Last edit: 09 Oct 2024 02:50 by Brooks McNew.
- Nick Arquer
09 Oct 2024 01:30 #6
by Nick Arquer
Replied by Nick Arquer on topic Throttle and mixture cable support
Thanks for the pics, I was planning a similar bracket location for my throttle cable. That mixture support is definitely interesting, but if it works.
Now I just need to figure out the panel to firewall support.
